Deactivate (all) filter(s) for one sync?
dirki-boy
How can I easily deactivate all the filters I have set in the filter settings for one sync without deleting them?
You can delete them (right-click the filter icon), but don't save.
dirki-boy
You can delete them (right-click the filter icon), but don't save.Zenju
Thank you Zenju,
Sorry for my bad expression, I meant without deleting, yes, I know you can delete them, so is there a way to disable the filters / filter settings without to have to delete them, so you could make a sync this time and may be the next time without the filters (otherwise you would have to fill in the extensions etc. again)?
No there is no direct way.
dirki-boy
OK, thank you.
