LOG File for RealTimeSync
Hi all, do you know how to get the LOG file in the case of Real Time Sync mode? I have to check if everything worked correctly and which files were copied.
RTS simply kicks off a CMD command-line, which is running your FFS config. The log will be with the other sync logs
