As the title states. This happens with FFS v14.2 on a Dell Precision notebook PC running Windows 11 Pro v24H2.
When the PC is manually wakened, FFS runs the batch job.
Batch job does not wake computer from sleep
FFS/RTS don't wake the computer up, they lack the ability to do so. This would have to be done via Task Scheduler or another method
The batch job task is set to wake up the computer. So it appears the problem is with the Task Scheduler.
Do you have any recommendations on diagnosing the Task Scheduler?
Thanks, Gary
Thanks, Gary
