When FFS v14.2 is opened following a batch job, the menu selection Actions -> Show log shows only an empty log.
Requesting to add a link to the latest log file. This avoids having to drill down into C:\Users\<username>\AppData\Roaming\FreeFileSync\Logs to see the log.
Feature request: Add link to current log file
Thanks,
Gary
Thanks,
Gary
"Actions -> Show log" shows you the log of the current sync. To view the most recent log for a sync, click the icon in the "Log" column for the corresponding sync config.
Thanks, I didn't know that column had links to the logs. I thought it simply showed the sync status.
Thanks, Gary
Thanks, Gary
