Move new folder pair
chota300
It is easy to add a new folder pair, and easy to move the new pair - if you remember how.
Since the right-click to move a pair does not function on the new pair just added at the top of the list, it is easy to forget how to move it. Luckily I found help in a forum.
But I think it would be much better to add instructions on moving a folder pair into the standard help pages.
And also even better would be to have an option where to add the pair in the list at the time the pair is added, rather than only at the top of the list.
Thank you.
The sequence in which your pairs are listed is not relevant for your sync.
It is at best relevant for your own "administration".
But, if you still want, you can click the black arrow in front of a folder pair and select Move Up or Move Down.
Via that same black arrow, you can (via the green "+" there) add a folder pair just above that specific folder pair, instead of at the top of all folder pairs (as when using the top green "+").
