HI Im not sure if this issue got any solution or not.
I saw a old post here
viewtopic.php?t=8493&hilit=mac+os+folder+locked#p29899
but no solution.
I need to sync windows and mac
but it painful the sync will fail due to the windows folder have a desktop.ini in it.
if the folder have the desktop.ini on mac side the folder will be created as a locked folder.
then you will never able to sync that folder.
I try to exclude the desktop.ini in freefilesync but it just don't sync the desktop.ini but still create the folder as a locked folder on mac side.
is there a way to stop file sync to create a folder with attribute? so stop mac side to created locked folder?
Folder always get locked on Mac side when sync with Windows host
the only workaround i have is manualy uncheck the locked flag on mac side.
but if there is too many folder. you will give up
