I get the following error when trying to synchronize. Any thoughts?
Cannot rename "C:\Users\jeffj\Dropbox\sync.ffs_db.e5bc.ffs_tmp" to "sync.ffs_db".
ERROR_SHARING_VIOLATION: The process cannot access the file because it is being used by another process. [MoveFileEx
Sync error
Same for me, only on the local DropBox folder. Usually pressing "Retry" solve the problem!
Honestly I do not rembember which was the last combination of DB and FFS versions that were wrking...
Currently:
DB version: 241.4.4853
FFS: 14.7
Currently:
FFS: 14.7
Looks like the solution is quite easy, if done by FFS itself!
viewtopic.php?t=7537#p25579
https://help.dropbox.com/files-folders/restore-delete/ignored-files
