Hi everyone
I'm trying to synchronize my computer with my online mailo cloud. Have got some .pdf on my cloud that I can't manage to synchronize on my computer. When I launch freefylesync it says that the file can't be write as it is an "unsupported character "" ". And it says that the name of the file is ***.ffs-tmp and not a pdf.
I don't now how to put a picture in my topic to be more clear, sorry. thanks for your help.
Emilie
Problem of synchronisation with my pdf
Does your PDF in the cloud contain an "Illegal" character in Windows? If so, you have to rename it
Thank you for your answer. I tried without the "é" and it worked. Thank you
é shouldn't be an issue (to FFS).
So maybe it is something the way that https://www.mailo.com/ is presenting that particular (or similar ?) characters (which you wouldn't really expect to be an issue, but...).
