gvfs bug
acg
The latest version 14.3, on the left side of the window, does not show the folders mounted in GVFS as a drive, and i have to provide the full path manually to sync them.
As seen in the image, there are three mounted folders (localsend, timeshift, ssd), but the FFS window only shows two.
Example path:
/run/user/1000/gvfs/smb-share:port=4445,server=192.168.1.131,share=localsend,user=root/music/va
SO: Ubuntu 24.04 Mate desktop
FFS: 14.3
Captura de pantalla -2025-04-04 12-37-46.png (7.22 KiB) Viewed 52799 times
Captura de pantalla -2025-04-04 12-32-40.png (136.56 KiB) Viewed 52806 times
Was the "localsend" mount shown in FFS versions before 14.3?
acg
Was the "localsend" mount shown in FFS versions before 14.3? Zenju, 05 Apr 2025, 09:20
Of course. check 14.2 image (normal edition)
PD. I use 14.3 Donation Edition
Captura de pantalla -2025-04-05 10-14-49.png (34.49 KiB) Viewed 52770 times
acg
I installed version 14.2. Then, I installed version 14.3 (I didn’t upgrade from 14.2 to 14.3, but ran the 14.3 installer), and the problem was fixed.
