New option of comparison
hapm
I have an issue with comparison (some dates are set to 01/01/1970 01:00:00). It seems an commun case. So it's seems to me helpfull to have a new option in comparison options after a File time and size comparison that confirme comparison with the file content (only if one of the date is 01/01/1970 01:00:00). What do you think about that ?
imajeff
Sounds to me like we need ability to script our own comparison, since if that's possible then why not any other combination of tests also
Keho
I've been having the same problem for several days on different PCs and a shared NAS.
The date on some files synced on the PC has changed to 01/01/1970.
therube
What NAS, what OS, & 32 or 64-bit at that?
What is the date or your source file & what OS is that system running?
1-1-1970 is a "magic" (UNIX) date.
I'll suspect that the source file date is dated earlier then 1-1-1970 & that your NAS/OS (including its' bitness) cannot handle such a date, so sets its date to 1-1-1970.
Keho
Exactly!
File details on the Linux NAS
Created 04/17/2025
Modified 01/01/1970 ????
Last accessed 04/17/2025
Keho
the attribute is checked in archive, when I uncheck it everything is ok
This has always been resolved on the NAS side. Make sure it is up to date
