In my solution FFS (even better the donation version) has all the functionalities I need. The connectivity bit is still missing: it's still unclear to me the pros and cons between Mountainduck/AirLiveDrive (i.e. commercial programs) and Rclone. May be someone could shed some light ?
Further it would be fantastic if a rclone user could share the command used to mount a OneDrive cloud.
Cloud connectivity for FFS
Hi @alone,
I'm working on a tips page and it will have in there instructions on how to do a basic mount with Google and Microsoft. There are flags that are important in the mount command.
I will also put into the tips page how I use another free tool to automatically mount my cloud drives when I log on to Windows.
I'll post the link when it's ready.
Every rclone command is full of flags and options and your tips would be really fantastic, I thank you in advance: it's something that is missing a lot (and even chatgpt doesn't help very much on this topic).
I know that is really unfair and rude but...could you give us an ETA for this page ?
Hi @alone
The page is online now but it's not complete.
Here is the url: https://dictanote.co/n/1144887/
There's a contact address at the bottom and if you use that you can request whatever you want in the document and I'll try and get it in there quickly.
