I have struggled a lot to sync my QNAP NAS TS-233 to sync with my local systems. Ultimately could get success to do it.
These days QSync app of QNAP does not have option to select oneway / selctive synchronisation. So i had to struggle a lot to get the ultimate solution, and moreover no forum or googling helped me to resolve the issue.
Here i am jotting my steps, it may help someone struggling.
Firstly define DDNS Name
Then Click Manage Alias Setting Button
Then Copy the URL defined in Alias as below
Now use the URL in Right side and select desired folder to sync at NAS end.
then select Left side to populate local folder and you are done.
now select compare, subsequently synchronization method (one way/both way/update/mirror etc.).
then press synchronize button to start syncing.
Hope this helps
Syncing With QNAP NAS TS-233
