FreeFileSync App for Andriod
rohitbhave
Free Files sync is an amazing software for use on Windows OS and I would love to have the same software on an Android phone as an app in the Google Play Store. The app can have similar features like the windows desktop version. It should have option to sync with Google Drive and One Drive as well, which should be it's main feature.
Now a days most of the phones don't have SD cards, and it would be helpful to have an app which can just move your stuff to the cloud and remove from the phone to free up space. Not exactly a sync, but a useful additional feature.
John1234
Check out this program called foldersync it might do what you want to do.
https://play.google.com/store/apps/details?id=dk.tacit.android.foldersync.lite
Otherwise I would recommend an SFTP server running on the phone.
https://play.google.com/store/apps/details?id=net.xnano.android.sshserver
