% gdb /opt/FreeFileSync/Bin/FreeFileSync_x86_64
GNU gdb (Ubuntu 15.1-1ubuntu2) 15.1
Copyright (C) 2024 Free Software Foundation, Inc.
License GPLv3+: GNU GPL version 3 or later <http://gnu.org/licenses/gpl.html>
This is free software: you are free to change and redistribute it.
There is NO WARRANTY, to the extent permitted by law.
Type "show copying" and "show warranty" for details.
This GDB was configured as "x86_64-linux-gnu".
Type "show configuration" for configuration details.
For bug reporting instructions, please see:
<https://www.gnu.org/software/gdb/bugs/>.
Find the GDB manual and other documentation resources online at:
<http://www.gnu.org/software/gdb/documentation/>.
For help, type "help".
Type "apropos word" to search for commands related to "word"...
Reading symbols from /opt/FreeFileSync/Bin/FreeFileSync_x86_64...
(No debugging symbols found in /opt/FreeFileSync/Bin/FreeFileSync_x86_64)
(gdb) run
Starting program: /opt/FreeFileSync/Bin/FreeFileSync_x86_64
This GDB supports auto-downloading debuginfo from the following URLs:
<https://debuginfod.ubuntu.com>
Enable debuginfod for this session? (y or [n]) y
Debuginfod has been enabled.
To make this setting permanent, add 'set debuginfod enabled on' to .gdbinit.
Downloading separate debug info for /lib/x86_64-linux-gnu/libexpat.so.1
[Thread debugging using libthread_db enabled]
Using host libthread_db library "/lib/x86_64-linux-gnu/libthread_db.so.1".
Downloading separate debug info for /lib/x86_64-linux-gnu/libharfbuzz.so.0
Downloading separate debug info for /lib/x86_64-linux-gnu/libbsd.so.0
Downloading separate debug info for /usr/lib/x86_64-linux-gnu/gio/modules/libgvfsdbus.so
Downloading separate debug info for /usr/lib/x86_64-linux-gnu/gvfs/libgvfscommon.so
[New Thread 0x7ffff5fff6c0 (LWP 22453)]
[New Thread 0x7fffed5ff6c0 (LWP 22454)]
[New Thread 0x7ffff57fe6c0 (LWP 22455)]
[New Thread 0x7ffff4ffd6c0 (LWP 22456)]
[New Thread 0x7fffeffff6c0 (LWP 22457)]
[New Thread 0x7fffef7fe6c0 (LWP 22458)]
[New Thread 0x7fffeeffd6c0 (LWP 22459)]
[Thread 0x7fffeeffd6c0 (LWP 22459) exited]
[New Thread 0x7fffeeffd6c0 (LWP 22460)]
Downloading separate debug info for /lib/x86_64-linux-gnu/libxml2.so.2
Downloading separate debug info for /lib/x86_64-linux-gnu/liblzma.so.5
[New Thread 0x7fffecdfe6c0 (LWP 22461)]
[New Thread 0x7fffd61ff6c0 (LWP 22462)]
[New Thread 0x7fffd59fe6c0 (LWP 22463)]
[New Thread 0x7fffd51fd6c0 (LWP 22464)]
[Thread 0x7fffd51fd6c0 (LWP 22464) exited]
[Thread 0x7fffd59fe6c0 (LWP 22463) exited]
[New Thread 0x7fffc3fff6c0 (LWP 22466)]
[New Thread 0x7fffd49fc6c0 (LWP 22465)]
[Thread 0x7fffc3fff6c0 (LWP 22466) exited]
[Thread 0x7fffd61ff6c0 (LWP 22462) exited]
[Thread 0x7fffd49fc6c0 (LWP 22465) exited]
[New Thread 0x7fffd49fc6c0 (LWP 22467)]
[New Thread 0x7fffd61ff6c0 (LWP 22468)]
[Thread 0x7fffd61ff6c0 (LWP 22468) exited]
[New Thread 0x7fffd61ff6c0 (LWP 22469)]
[Thread 0x7fffd61ff6c0 (LWP 22469) exited]
[New Thread 0x7fffd61ff6c0 (LWP 22483)]
[Thread 0x7fffd61ff6c0 (LWP 22483) exited]
[New Thread 0x7fffc3fff6c0 (LWP 22484)]
[Thread 0x7fffc3fff6c0 (LWP 22484) exited]
[New Thread 0x7fffc3fff6c0 (LWP 22485)]
[New Thread 0x7fffd61ff6c0 (LWP 22486)]
[Thread 0x7fffd61ff6c0 (LWP 22486) exited]
[New Thread 0x7fffd51fd6c0 (LWP 22487)]
[Thread 0x7fffd51fd6c0 (LWP 22487) exited]
[Thread 0x7fffc3fff6c0 (LWP 22485) exited]
[New Thread 0x7fffc3fff6c0 (LWP 22488)]
[New Thread 0x7fffd51fd6c0 (LWP 22490)]
[New Thread 0x7fffd59fe6c0 (LWP 22492)]
[New Thread 0x7fffd61ff6c0 (LWP 22491)]
[New Thread 0x7fffc37fe6c0 (LWP 22493)]
[Thread 0x7fffc37fe6c0 (LWP 22493) exited]
[Thread 0x7fffd61ff6c0 (LWP 22491) exited]
[Thread 0x7fffd59fe6c0 (LWP 22492) exited]
[Thread 0x7fffd51fd6c0 (LWP 22490) exited]
[Thread 0x7fffc3fff6c0 (LWP 22488) exited]
[Thread 0x7fffecdfe6c0 (LWP 22461) exited]
[New Thread 0x7fffecdfe6c0 (LWP 22501)]
[Thread 0x7fffd49fc6c0 (LWP 22467) exited]
Thread 1 "FreeFileSync_x8" received signal SIGSEGV, Segmentation fault.
pango_coverage_get (coverage=0x0, index=84) at ../pango/pango-coverage.c:183
warning: 183 ../pango/pango-coverage.c: No such file or directory
(gdb) bt
#0 pango_coverage_get (coverage=0x0, index=84) at ../pango/pango-coverage.c:183
#1 0x00007ffff749160f in pango_font_default_has_char (font=<optimized out>, wc=84) at ../pango/fonts.c:1795
#2 0x00007ffff748d68a in get_font_foreach (fontset=0xe2f78e0, font=0xe2f96a0, data=0x7fffffff9950) at ../pango/itemize.c:749
#3 0x00007ffff7cbacb9 in pango_fc_fontset_foreach (fontset=0xe2f78e0, func=0x7ffff748d660 <get_font_foreach>, data=0x7fffffff9950) at ../pango/pangofc-fontmap.c:1404
#4 0x00007ffff74c096b in get_font.isra.0 (state=state@entry=0x7fffffff9a30, wc=wc@entry=84, font=font@entry=0x7fffffff9a28, position=position@entry=0x7fffffff9a24) at ../pango/itemize.c:796
#5 0x00007ffff7492c4d in itemize_state_process_run (state=0x7fffffff9a30) at ../pango/itemize.c:984
#6 pango_itemize_with_font
(context=<optimized out>, base_dir=<optimized out>, text=0xe2f2860 "The quick brown fox jumps over the lazy dog.", start_index=<optimized out>, length=<optimized out>, attrs=<optimized out>, cached_iter=0x7fffffffa170, desc=0x0)
at ../pango/itemize.c:1570
#7 0x00007ffff74a7c0e in pango_layout_check_lines.part.0.lto_priv.0 (layout=<optimized out>) at ../pango/pango-layout.c:4900
#8 0x00007ffff749c16e in pango_layout_check_lines (layout=<optimized out>) at ../pango/pango-layout.c:4792
#9 pango_layout_get_extents_internal (layout=layout@entry=0xe2f2a20, ink_rect=ink_rect@entry=0x0, logical_rect=logical_rect@entry=0x7fffffffa4b0, line_extents=line_extents@entry=0x0) at ../pango/pango-layout.c:2925
#10 0x00007ffff749c2e0 in pango_layout_get_extents (layout=layout@entry=0xe2f2a20, ink_rect=ink_rect@entry=0x0, logical_rect=logical_rect@entry=0x7fffffffa4b0) at ../pango/pango-layout.c:3118
#11 0x00007ffff7d01a39 in _pango_cairo_font_get_metrics (font=<optimized out>, language=<optimized out>) at ../pango/pangocairo-font.c:293
#12 0x00007ffff74a63d3 in pango_layout_run_get_extents_and_height (run=0xe2f28a0, run_ink=run_ink@entry=0x7fffffffa630, run_logical=0x7fffffffa550,
run_logical@entry=0x0, line_logical=line_logical@entry=0x7fffffffa620, height=height@entry=0x7fffffffa61c) at ../pango/pango-layout.c:5719
#13 0x00007ffff74a7153 in pango_layout_line_get_extents_and_height.part.0.lto_priv.0 (line=0x29e7e60, ink_rect=<optimized out>, logical_rect=<optimized out>, height=<optimized out>) at ../pango/pango-layout.c:5836
#14 0x00007ffff749bc06 in pango_layout_line_get_extents_and_height (line=0x29e7e60, ink_rect=0x0, logical_rect=0x7fffffffa6b0, height=0x7fffffffa6a8) at ../pango/pango-layout.c:5779
#15 get_line_extents_layout_coords
(layout=layout@entry=0x2ab7850, line=0x29e7e60, layout_width=layout_width@entry=-1, y_offset=0, baseline=baseline@entry=0x7fffffffa76c, line_ink_layout=line_ink_layout@entry=0x0, line_logical_layout=0x7fffffffa770)
at ../pango/pango-layout.c:2877
#16 0x00007ffff749c02c in pango_layout_get_extents_internal (layout=0x2ab7850, ink_rect=<optimized out>, ink_rect@entry=0x0, logical_rect=<optimized out>, logical_rect@entry=0x7fffffffa7e0, line_extents=line_extents@entry=0x0)
at ../pango/pango-layout.c:3001
#17 0x00007ffff749c2e0 in pango_layout_get_extents (layout=<optimized out>, ink_rect=ink_rect@entry=0x0, logical_rect=logical_rect@entry=0x7fffffffa7e0) at ../pango/pango-layout.c:3118
#18 0x00007ffff749c32d in pango_layout_get_size (layout=<optimized out>, width=0x7fffffffaa50, height=0x7fffffffa970) at ../pango/pango-layout.c:3166
#19 0x00007ffff74a9ae6 in pango_layout_check_lines.part.0.lto_priv.0 (layout=<optimized out>) at ../pango/pango-layout.c:4983
#20 0x00007ffff749c16e in pango_layout_check_lines (layout=<optimized out>) at ../pango/pango-layout.c:4792
#21 pango_layout_get_extents_internal (layout=0x2ab7850, ink_rect=ink_rect@entry=0x0, logical_rect=logical_rect@entry=0x7fffffffac20, line_extents=line_extents@entry=0x0) at ../pango/pango-layout.c:2925
#22 0x00007ffff74a0164 in pango_layout_get_pixel_size (layout=<optimized out>, width=0x7fffffffae28, height=0x7fffffffae2c) at ../pango/pango-layout.c:3194
#23 0x0000000001092031 in ??? ()
#24 0x0000000000fe1b16 in ??? ()
#25 0x0000000000f031c5 in ??? ()
#26 0x000000000077a2f1 in ??? ()
#27 0x000000000077adbd in ??? ()
#28 0x000000000077c7dc in ??? ()
#29 0x0000000000921d53 in ??? ()
#30 0x0000000000922f1d in ??? ()
#31 0x0000000001252e08 in ??? ()
#32 0x0000000001253bee in ??? ()
#33 0x0000000001253cc0 in ??? ()
#34 0x0000000001253d6a in ??? ()
#35 0x0000000001253e11 in ??? ()
#36 0x0000000000f00359 in ??? ()
#37 0x0000000000f00a24 in ??? ()
#38 0x00007ffff794b480 in gtk_marshal_BOOLEAN__POINTER (closure=0x27ef780, return_value=0x7fffffffb8b0, param_values=0x7fffffffb940, marshal_data=<optimized out>, invocation_hint=<optimized out>, n_param_values=<optimized out>)
at ../../../../gtk/gtkmarshal.c:121
#39 0x00007ffff73d245a in g_closure_invoke (closure=0x27ef780, return_value=0x7fffffffb8b0, n_param_values=2, param_values=0x7fffffffb940, invocation_hint=0x7fffffffb890) at ../../../gobject/gclosure.c:833
#40 0x00007ffff74023a3 in signal_emit_unlocked_R.isra.0
(node=node@entry=0x7fffffffba50, detail=detail@entry=0, instance=instance@entry=0x27ef600, emission_return=emission_return@entry=0x7fffffffbad0, instance_and_params=instance_and_params@entry=0x7fffffffb940)
at ../../../gobject/gsignal.c:3887
#41 0x00007ffff73f271c in signal_emit_valist_unlocked (instance=instance@entry=0x27ef600, signal_id=signal_id@entry=41, detail=detail@entry=0, var_args=var_args@entry=0x7fffffffbbc0) at ../../../gobject/gsignal.c:3532
#42 0x00007ffff73f3181 in g_signal_emit_valist (instance=0x27ef600, signal_id=41, detail=0, var_args=var_args@entry=0x7fffffffbbc0) at ../../../gobject/gsignal.c:3262
#43 0x00007ffff73f3243 in g_signal_emit (instance=instance@entry=0x27ef600, signal_id=<optimized out>, detail=detail@entry=0) at ../../../gobject/gsignal.c:3582
#44 0x00007ffff7a8d3dc in gtk_widget_event_internal (widget=0x27ef600, event=0x7fffffffbdc0) at ../../../../gtk/gtkwidget.c:5017
#45 0x00007ffff7953886 in IA__gtk_main_do_event (event=0x7fffffffbdc0) at ../../../../gtk/gtkmain.c:1637
#46 IA__gtk_main_do_event (event=<optimized out>) at ../../../../gtk/gtkmain.c:1517
#47 0x00007ffff7d86649 in _gdk_window_process_updates_recurse (window=window@entry=0x29efb40, expose_region=expose_region@entry=0x2a93a40) at ../../../../gdk/gdkwindow.c:5479
#48 0x00007ffff7d865c3 in _gdk_window_process_updates_recurse (window=0x29efb40, expose_region=0x2a93a40) at ../../../../gdk/gdkregion-generic.c:1545
#49 _gdk_window_process_updates_recurse (window=window@entry=0x29ec540, expose_region=expose_region@entry=0x29c51e0) at ../../../../gdk/gdkwindow.c:5452
#50 0x00007ffff7d865c3 in _gdk_window_process_updates_recurse (window=0x29ec540, expose_region=0x29c51e0) at ../../../../gdk/gdkregion-generic.c:1545
#51 _gdk_window_process_updates_recurse (window=window@entry=0x2a03510, expose_region=expose_region@entry=0x29b5970) at ../../../../gdk/gdkwindow.c:5452
--Type <RET> for more, q to quit, c to continue without paging--
#52 0x00007ffff7d865c3 in _gdk_window_process_updates_recurse (window=0x2a03510, expose_region=0x29b5970) at ../../../../gdk/gdkregion-generic.c:1545
#53 _gdk_window_process_updates_recurse (window=window@entry=0x29996b0, expose_region=expose_region@entry=0x29db720) at ../../../../gdk/gdkwindow.c:5452
#54 0x00007ffff7d865c3 in _gdk_window_process_updates_recurse (window=0x29996b0, expose_region=0x29db720) at ../../../../gdk/gdkregion-generic.c:1545
#55 _gdk_window_process_updates_recurse (window=window@entry=0x28d0c30, expose_region=expose_region@entry=0x29c7070) at ../../../../gdk/gdkwindow.c:5452
#56 0x00007ffff7d865c3 in _gdk_window_process_updates_recurse (window=0x28d0c30, expose_region=0x29c7070) at ../../../../gdk/gdkregion-generic.c:1545
#57 _gdk_window_process_updates_recurse (window=0x28cdeb0, expose_region=0x29e5ed0) at ../../../../gdk/gdkwindow.c:5452
#58 0x00007ffff7d7b6b4 in gdk_window_process_updates_internal (window=window@entry=0x28cdeb0) at ../../../../gdk/gdkregion-generic.c:1545
#59 0x00007ffff7d7c644 in IA__gdk_window_process_updates (window=0x29996b0, update_children=1) at ../../../../gdk/gdkwindow.c:5818
#60 IA__gdk_window_process_updates (window=0x29996b0, update_children=1) at ../../../../gdk/gdkwindow.c:5794
#61 0x0000000000efc60c in ??? ()
#62 0x0000000000d6e425 in ??? ()
#63 0x0000000000829ec6 in ??? ()
#64 0x0000000000887a1e in ??? ()
#65 0x0000000001252df5 in ??? ()
#66 0x0000000001253bee in ??? ()
#67 0x0000000001253cc0 in ??? ()
#68 0x0000000001253d6a in ??? ()
#69 0x0000000001253e11 in ??? ()
#70 0x0000000000f0af06 in ??? ()
#71 0x00007ffff73d245a in g_closure_invoke (closure=0x273b100, return_value=0x0, n_param_values=1, param_values=0x7fffffffcd70, invocation_hint=0x7fffffffccc0) at ../../../gobject/gclosure.c:833
#72 0x00007ffff74026fd in signal_emit_unlocked_R.isra.0
(node=node@entry=0x7fffffffce60, detail=detail@entry=0, instance=instance@entry=0x2740d10, emission_return=emission_return@entry=0x0, instance_and_params=instance_and_params@entry=0x7fffffffcd70) at ../../../gobject/gsignal.c:3960
#73 0x00007ffff73f2f0d in signal_emit_valist_unlocked (instance=instance@entry=0x2740d10, signal_id=signal_id@entry=134, detail=detail@entry=0, var_args=var_args@entry=0x7fffffffcfd0) at ../../../gobject/gsignal.c:3519
#74 0x00007ffff73f3181 in g_signal_emit_valist (instance=0x2740d10, signal_id=134, detail=0, var_args=var_args@entry=0x7fffffffcfd0) at ../../../gobject/gsignal.c:3262
#75 0x00007ffff73f3243 in g_signal_emit (instance=instance@entry=0x2740d10, signal_id=<optimized out>, detail=detail@entry=0) at ../../../gobject/gsignal.c:3582
#76 0x00007ffff789c02d in IA__gtk_button_clicked (button=button@entry=0x2740d10) at ../../../../gtk/gtkbutton.c:1115
#77 0x00007ffff789c099 in gtk_real_button_released (button=0x2740d10) at ../../../../gtk/gtkbutton.c:1712
#78 gtk_real_button_released (button=0x2740d10) at ../../../../gtk/gtkbutton.c:1702
#79 0x00007ffff73d245a in g_closure_invoke (closure=0x249b960, return_value=0x0, n_param_values=1, param_values=0x7fffffffd2b0, invocation_hint=0x7fffffffd200) at ../../../gobject/gclosure.c:833
#80 0x00007ffff74024d0 in signal_emit_unlocked_R.isra.0
(node=node@entry=0x7fffffffd3a0, detail=detail@entry=0, instance=instance@entry=0x2740d10, emission_return=emission_return@entry=0x0, instance_and_params=instance_and_params@entry=0x7fffffffd2b0) at ../../../gobject/gsignal.c:3720
#81 0x00007ffff73f2f0d in signal_emit_valist_unlocked (instance=instance@entry=0x2740d10, signal_id=signal_id@entry=133, detail=detail@entry=0, var_args=var_args@entry=0x7fffffffd510) at ../../../gobject/gsignal.c:3519
#82 0x00007ffff73f3181 in g_signal_emit_valist (instance=0x2740d10, signal_id=133, detail=0, var_args=var_args@entry=0x7fffffffd510) at ../../../gobject/gsignal.c:3262
#83 0x00007ffff73f3243 in g_signal_emit (instance=instance@entry=0x2740d10, signal_id=<optimized out>, detail=detail@entry=0) at ../../../gobject/gsignal.c:3582
#84 0x00007ffff789c89d in gtk_button_released (button=button@entry=0x2740d10) at ../../../../gtk/gtkbutton.c:1107
#85 0x00007ffff789c8d9 in gtk_button_button_release (widget=widget@entry=0x2740d10, event=<optimized out>) at ../../../../gtk/gtkbutton.c:1604
#86 0x00007ffff794b480 in gtk_marshal_BOOLEAN__POINTER (closure=0x1db2510, return_value=0x7fffffffd790, param_values=0x7fffffffd820, marshal_data=<optimized out>, invocation_hint=<optimized out>, n_param_values=<optimized out>)
#87 0x00007ffff73d245a in g_closure_invoke (closure=0x1db2510, return_value=0x7fffffffd790, n_param_values=2, param_values=0x7fffffffd820, invocation_hint=0x7fffffffd770) at ../../../gobject/gclosure.c:833
#88 0x00007ffff7402980 in signal_emit_unlocked_R.isra.0
(node=node@entry=0x7fffffffd930, detail=detail@entry=0, instance=instance@entry=0x2740d10, emission_return=emission_return@entry=0x7fffffffd9b0, instance_and_params=instance_and_params@entry=0x7fffffffd820)
at ../../../gobject/gsignal.c:3927
#89 0x00007ffff73f271c in signal_emit_valist_unlocked (instance=instance@entry=0x2740d10, signal_id=signal_id@entry=34, detail=detail@entry=0, var_args=var_args@entry=0x7fffffffdaa0) at ../../../gobject/gsignal.c:3532
#90 0x00007ffff73f3181 in g_signal_emit_valist (instance=0x2740d10, signal_id=34, detail=0, var_args=var_args@entry=0x7fffffffdaa0) at ../../../gobject/gsignal.c:3262
#91 0x00007ffff73f3243 in g_signal_emit (instance=instance@entry=0x2740d10, signal_id=<optimized out>, detail=detail@entry=0) at ../../../gobject/gsignal.c:3582
#92 0x00007ffff7a8d3dc in gtk_widget_event_internal (widget=0x2740d10, event=0x29b3950) at ../../../../gtk/gtkwidget.c:5017
#93 0x00007ffff7951ebb in IA__gtk_propagate_event (widget=0x2740d10, event=0x29b3950) at ../../../../gtk/gtkmain.c:2522
#94 IA__gtk_propagate_event (widget=widget@entry=0x2740d10, event=event@entry=0x29b3950) at ../../../../gtk/gtkmain.c:2459
#95 0x00007ffff7952dab in IA__gtk_main_do_event (event=0x29b3950) at ../../../../gtk/gtkmain.c:1712
#96 IA__gtk_main_do_event (event=<optimized out>) at ../../../../gtk/gtkmain.c:1517
#97 0x00007ffff7da002e in gdk_event_dispatch (source=<optimized out>, callback=<optimized out>, user_data=<optimized out>) at x11/../../../../../gdk/x11/gdkevents-x11.c:2425
#98 0x00007ffff72cc397 in g_main_dispatch (context=0x1dabd30) at ../../../glib/gmain.c:3357
#99 0x00007ffff732cdc7 in g_main_context_dispatch_unlocked (context=0x1dabd30) at ../../../glib/gmain.c:4208
#100 g_main_context_iterate_unlocked.isra.0 (context=0x1dabd30, block=block@entry=1, dispatch=dispatch@entry=1, self=<optimized out>) at ../../../glib/gmain.c:4273
#101 0x00007ffff72cd097 in g_main_loop_run (loop=0x2479e90) at ../../../glib/gmain.c:4475
#102 0x00007ffff7950fb1 in IA__gtk_main () at ../../../../gtk/gtkmain.c:1284
#103 0x000000000108b9d5 in ??? ()
#104 0x00000000011618dd in ??? ()
#105 0x000000000112d253 in ??? ()
#106 0x0000000000586c79 in ??? ()
#107 0x00000000011a3184 in ??? ()
#108 0x000000000055a802 in ??? ()
#109 0x00007ffff6e2a3b8 in __libc_start_call_main (main=main@entry=0x55a7f0, argc=argc@entry=1, argv=argv@entry=0x7fffffffe0a8) at ../sysdeps/nptl/libc_start_call_main.h:58
#110 0x00007ffff6e2a47b in __libc_start_main_impl (main=0x55a7f0, argc=1, argv=0x7fffffffe0a8, init=<optimized out>, fini=<optimized out>, rtld_fini=<optimized out>, stack_end=0x7fffffffe098) at ../csu/libc-start.c:360
(gdb) disassemble
Dump of assembler code for function pango_coverage_get:
0x00007ffff74976e0 <+0>: endbr64
=> 0x00007ffff74976e4 <+4>: mov (%rdi),%rax
0x00007ffff74976e7 <+7>: jmp *0x88(%rax)
End of assembler dump.
Crash in kubuntu 24.10
FreeFileSync 14.3 always crashes in kubuntu 24.10. I'll be upgrading to kubuntu 25.04 as soon as the update is available, which has been halted due to issues with pyqt6. Here's the log:
Works fine in kubuntu 25.04, it was an issue caused by old software.
