Shutdown Computer and Backup Server on completion
MegaLuigiSisters
when i go to "Synchronization Settings" i can chosse on or more commands to run after completion. This works. When i start a sync there is an extra field "When finished". But here i can't select the commands that i can select "Synchronization Settings". It would be better when i can select here what to do after completion.
When i select "shutdown" and later while the process is still running i decide not to turn off the computer i can change this here without stopping the sync.
Or do i understand something wrong?
