Expandable files list in compare view
GLC
I'm writing to ask about a feature that I either don't know how to use or that might not exist. Basically, when I compare the folder I want to sync with the backup folder, the software gives me a list of all the files that need to be synchronized, organized by folder. However, I often find that there are a lot of files, and if I want to check whether there's a folder I need to exclude or not, I have to scroll a lot, which is really annoying. Would it be possible to add a feature to expand and collapse folders, so that I only see the folder name or the last folder in the path? That way, I could scroll much faster without going crazy.
Thanks for the help and love the project!
GLC
Gianni1962
On the left, under the Configuration section, there is the Overview section with expandable/collapsible folders, may be this is what you are looking for.
Antonio.A
The Overview section is only useful to navigate the folders in the path (the main view, under Compare/Synchronize).
I agree with GLC, asking for a feature that really collapse or expand each folder in the main view.
Thank you for the project!
