The night version (dark)
milafabio
on mac OS dark mode at night, the program has white bars in the panel where the file is for synchronization. You can see it in the panel on the left. in the panel on the right, I have highlighted the files and then the names are visible.
I suspect that system dark mode became active while FFS was running, which isn't supported. An app restart will fix the color glitch.
