After every sync, I receive the error message as follows:
5:22:27 PM Error Cannot write file "C:\Users\gmg\AppData\Roaming\FreeFileSync\Logs\Omni Quicken+ScanSnap 2025-05-28 172140.444.html".
Cannot create directory "C:\Users\gmg".
ERROR_ACCESS_DENIED: Access is denied. [CreateDirectory]
There is no gmg user. The correct path should be :
C:\Users\gmg22\AppData\Roaming\FreeFileSync\Logs\Omni
But, I do not know where or how to correct this in FreeFile Sync?
Error Message recording log files!
Go to Tools / Options and edit Default log folder.
Thanks , that did the trick. I was not aware of that before you advised me of that simple solution.
