Hi there,
I do 4 hourly, daily back ups ( 2 back ups ) and weekly back up on our current file server. I have them all in in scheduled tasks. All of them work perfectly except one of the daily back ups. I get an error saying 'An Exceptional Error Occurred : Contract Violation- (c)Program files/C++/Freefilesync/Projects/cpp 437'
I can't even find that folder that contains that error file in both locations. I also have an issue with the sync lock file. is there no way of disabling it?
thanks,
An exceptional error : Contract Violation
Can you please give the precise error message description, or better yet a screenshot?
Hi Zenju,
apologies for the delayed reply. I've attached the error message.
Which version of FFS are you using?
Version 5.10
I think I know what the problem is. Are you able to reproduce the error in FFS 5.22? In this case I can create a test version to see if the expected fix does in fact work.
do you want me to update to 5.22 to see if I get the same probem?
It's sufficient to install 5.22 in parallel as a portable version, then test.
Hi Zenju,
It worked ! thanks so much ! :)
Well... :) the 5.22 also has the "contract violation" bug, which I assume to be incorrect handling of an out of memory situation, so you're probably just lucky. Anyway 5.23 should fix this type of bug by handling all cases correctly.Hi Zenju,
It worked ! thanks so much ! :)bbenergy
