Two way syncing one folder for multiple computers
andre-m-faria
Hello, I've read many posts but didn't found one very similar to my problem in question.
I'm using two computers they will sync (Two way) one folder /home/myuser/documents/mydocs to my gDrive account configured in FFS.
Which means
ComputerA will sync (two way) '../mydocs' to gdrive:/myaccount@gmail.com/mydocs
ComputerB will sync (two way) '../mydocs' to gdrive:/myaccount@gmail.com/mydocs
They will never sync at the same time as they are not powered on simultaneously.
This will work? I need to remove .sync.ffs_db from source or remote for any reason?
Thanks in advance.
Edit: Forgot to mention is two way syncing.
This should work perfectly fine, without any tweaking
andre-m-faria
Thank you for you answer, yes its working like a charm.
