synchronization alert
avdl
Launching synchronization betwen "C:\Program Files\IBM\Lotus\Notes\Data\archive" to "\\ntrbx.local\mediatheque\sauvegarde\document actuel\Andre2\Archives Lotus", i get this message
"A folder will be modified which is part of multiple folder pairs. Please review synchronization settings."
"C:\Program Files\IBM\Lotus\Notes\Data\archive" only contains files and no folders
Ignoring this alert will make synchronization run ok through.
I can't understand the meaning of this alert and the way to solve this problem?
Any clue ?
Thanks,
André
You have a setup like
A - B
A - C
and for both folder pairs there is an access, of which at least one is a write. Due to FFS's concept of first comparing all folder pairs, then sync'ing all pairs, this could be a problem.
avdl
I only have two pairs:
1 - C:\Program Files\IBM\Lotus\Notes\Data\archive -> \\ntrbx.local\mediatheque\sauvegarde\document actuel\Andre2\Archives Lotus
2 - %HOMEPATH%\Mes documents -> //ntrbx.local/mediatheque/sauvegarde/document actuel/Andre2
Both are strict copies (Mise à jour) from left to right.
I can't guess where conflict could be ?
does line order have an importance ?
Thanks,
André
is a subfolder of:
So it is possible that the same files are overwritten in both folder pairs.
avdl
Great, i got it !
Thanks,
André
