File Locked by another process (problem started maybe last week?)
eahm
Did anyone else started having this problem? FFS was fine until last week then something happened, maybe a MS update, but now it doesn't copy files "locked by another process", for example: quickbooks, outlook PST etc.
Do I need to change anything in my configuration, again, it was perfectly fine until last week.
Thanks.
eahm
The "Copy locked files" box was unchecked. Issue solved, sorry for the trouble.
