Problem with invisible file
k.kozerski
Hi, I'm having a problem dyring mirror syncing files from drive D to drive E.
Pojawia się taki błąd i komunikat:
Cannot be moved
"E:\DumpStack.log.tmp" to
"E:\RecycleBin~f4cd.ffs_tmp\DumpStack.log.tmp".
I can't see this file and dont't know and I don't know how to solve this problem.
Thanks for your help
It is a hidden system file, you can't see it without changing some settings. I would recommend just excluding from the sync entirely, this can be done in the configuration settings.
k.kozerski
Thank you for your answer.
But how do I do it?
