sorry for the question that could sound silly for advanced users, but I have not found a way to force the update of a file whatever the comparison says. also the search on this forum has not given me hints.
Due to the large size of the files, I need to avoid to compare the folders by content, but I have a single small encrypted file which, if modified, is not recognized as to be copied (the date and size do not change).
Forcing the update of one file
At that point, just use CMD to copy and overwrite that one file. You could have FFS run a command on completion of the sync to handle it
Thanks. I just wanted to make sure that there was no way to deal with this directly in the GUI. I will follow your advice.
