Good meowning! I want to run RealTimeSync from my local directory (D:/) to my SMB share (Z:/Family PC Backup). But I am met with the following error:
Cannot monitor directory "D:\".
Corrupt data returned. [ReadDirectoryChangesW]
To be honest, I have only met this error after forcibly removing the old D:/Windows in that disk using a live Linux USB installer. Which I now obviously regret doing, 'cuz before that, I had no problems with RealTimeSync.
FreeFileSync still works. Any suggestions on how to fix this? I am afraid to run any "disk fixers" program on this disk as I might brick this any further, so any tips will be appreciated.
Thank you and have a great day every-nyan~
Cannot monitor directory; Corrupt data returned. [ReadDirectoryChangesW]
Run a chkdsk on the volume
So RTS fails, yet FFS itself is still working?
Prior to /windows/ removal, were you syncing the entire D: drive (& set /windows/ as an exclude) or did you have individual directory pairs set up?
So were your pairs:
D:\ [+exclude /windows/] -> Z:/Family PC Backup/D/
or something like:
D:/musc/ -> Z:/Family PC Backup/music/
D:/video/ -> Z:/Family PC Backup/video/
D:/doc/ -> Z:/Family PC Backup/doc/
If the former, then maybe the deletion of /windows/ (somewhat) screwed up something, in the root, D: (that maybe chkdsk will fix)?
If the latter, if you were to attempt the former, in FFS, would that then also give you the same error message?
Explain D:/windows/?
It is a separate drive, that at one point was a C: drive (& now used as a "data" drive)?
Or you installed Windows both onto C: & also onto D:?
(As it is, I install Windows onto E:, though I also have a copy on C: - that never gets used.)
(I'm thinking that using Linux to remove /windows/ was probably a good thing, all in all.
As in Windows can be weird, like if you were in d:/users/joe/appdata/... you might find yourself [unwantedly] staring at the c:/user/joe/... equivalent. [Some distant memory points me to oddities in that regard.])
So were your pairs:
or something like:
Similarly, are you using directly pairs like above, D:\ -> Z:/ or D:/music/ -> Z:/.../music/ ?FreeFileSync still works
