Temporarily deactivate synchronization for individual folders
fraubi
I would appreciate a feature that allows you to disable individual folder synchronizations within a created backup job.
My backup job contains a total of 15 folder pairs that are synchronized. Sometimes, however, it's only necessary to synchronize one of the 15 folders, if only to save time. Since all the jobs run each time, it takes an unnecessarily long time.
As you can see in the image, I would like to synchronize only the yellow-highlighted directory once and disable synchronization for all other folders.
Click the "-" to remove the other folder pairs, and then simply reload the config to get them back
