w Error code 0x17c: The cloud operation is invalid. [CopyFileEx]hat does this error mean
I am backing up from a one drive to an external hard drive, i get this message above and the backup is only 59% complete. Can anybody help me with this thank you.
Is OneDrive set to save all files locally?
Your reply has helped me to sort out the problem, many thanks xxIs OneDrive set to save all files locally? xCSxXenon, 04 Sep 2025, 00:22
The syncing of my One Drives had been paused as I had used a program to transfer all my apps and information to a new computer, so hence the error message, I have turned them back on and the file sync softwear has now done a full mirror of the one drive to external hard drive 👍
