Need A Little Help
Smyth Wx
I'm a new user and have not quite got everything working as it should. I need to sync radar images from a file on my server to a directory on my web server. I have been able to accomplish this manually but I haven't got the automated part licked and it looks like I may have spoken too soon on the manual part as it wants to create and extra duplicate directory when I run it manually. If someone could help me sort out this mess I've created I'd be grateful for the assistance.
Thanks In Advance
Wayne Thomas
Smyth Wx
Smyth Wx
I've made a little progress with this setup. I have successfully been able to manually sync the files but I cannot for the life of me get the files to compare then log on to the web server and upload the required images. I can't seem to be able to create a command line statement to make these things happen
How is the web server accessed? FTP?
Smyth Wx
Yes it's accessed by SFTP
Thanks!
You likely chose the wrong location on one side or the other. Can you post a screenshot of the FFS window with the paths showing? Click "Editor & Preview" below to attach a file.
In lieu of that, my best explanation, assuming 'mirror' sync:
FFS makes the directory you select on the right side look exactly like the directory you select on the left side. If your setup is wanting to create a new and extra directory, you may have selected too deep or shallow of a folder.
Smyth Wx
Sure be glad to Do you need a screen cap of the Real Time Sync app as well or just the main program ?
Wayne
