I just created a backup job which copies C:\Users\Jaws4\AppData\Roaming\Mozilla to another location.
In the above folder are 2 other folders:
"Extensions" & "Firefox"
"Extensions" is actually empty and "firefox" contains lots of data and folders
When I execute this - ONLY the "Extension" folder is copied. "Firefox" is ignored completely.
I cannot force this to copy the "Firefox" folder unless I create 2 separate jobs to copy the 2 folders separately. I shouldn't of course HAVE to do this.
What is even more weird is if I make a copy of Firefox folder eg. "Firefox_copy", this folder is copied no problem. I'm at a loss to figure out what is the issue.
Any idea what might be going on here??
weird sync issue where a folder is ignored
It is looking very much like it won't copy this folder all the time it's called "Firefox".
If I rename it eg. "firefox_" - no problem. Rename it back to "Firefox" ... nope. Is this a bug or a feature???
Check your filters
100% on the button ... thanks so much !Check your filters xCSxXenon, 16 Sep 2025, 01:46
Been around the block lol
Glad it's working
Glad it's working
I hadn't thought about that actually. I put a filter in as I had a backup to do personal folders and stuff.Been around the block lol
Glad it's working xCSxXenon, 16 Sep 2025, 02:30
I'll be sure to check in future. thanks again.
