macOS Tahoe 26 compatibility
nemosync
Anyone tried the SW with the new OS version?
Does it work fine?
thanks
RJa
I'm using version 14.4 on MacOS 26.0. The application installs and functions correctly for my use case, which is manually synchronizing directories and files to external SSD devices.
nemosync
I'm using version 14.4 on MacOS 26.0. The application installs and functions correctly for my use case, which is manually synchronizing directories and files to external SSD devices. RJa, 19 Sep 2025, 15:39
