Please excuse my poor English, so I used Google to translate.
I want to filter files of a single file format from a folder with multiple folders and subfolders and sync them to a USB stick.
But instead of dividing them into folders and subfolders again, I want them all to be in a single folder.
I've enclosed "*.epub" and that filters out the files. It works.
But how do I get them onto the stick without all the folders and subfolders?
Files from multiple folders into a single folder
viewtopic.php?t=12375
FFS isn't the right tool for your use, as you are no longer syncing.
