XML and other files don't upload properly on Autodesk Desktop Connector
rrogRM
When syncing XML files from my local drive to my Autodesk Desktop Connector drive, they will not upload properly. I need to run the troubleshooting tool on the Desktop Connector to force them to sync/upload. I have tested doing a regular copy/paste and they will upload just fine. It's only when I use FFS that they error.
Thanks!
therube
Is there any sort of error message given (or log) as to why they failed?
rrogRM
I just downloaded the latest Desktop Connector version (October 1st) and it appears to have fixed the issue.
