[Feature Request] Downloading Google's Office Documents locally
cloudstudio
Hi longtime user, first time poster. My thanks for creating and maintaining FFS.
Currently I use FFS to keep a few folders in sync between my Local & GDrive. The main problem I've been facing has been with syncing Google Docs/Sheets/Slides files locally. Currently FFS shows them as binary files without any extension with no way to open them locally. I have to exclude them all-together, but in that situation I hate to think that those files only exist on GDrive.
What I propose is to download GDocs → .docx , GSheets → .xlsx & GSlides → .pptx.
This is feature is already implemented by other oss like `rc`, so the implementation can be inspired from there. It would be awesome to have this feature in FFS.
Thanks.
krmanr
FYI, I have experienced errors with syncing any "gdoc" file.
Aimdezilaere
Same issue here, and same longing - I have a lot of documentation in GDocs and GSheets 😬
therube
(I have no knowledge of gdrive...)
Are the files within the GDocs, GSheets & GSlides "directories" solely .docx, .xlsx & .pptx. files?
(Or are you apt to have any general file type in said directories?)
If the former, could you run a post sync command that renames any files in the G directories that do not have an extension, to .docx... (as appropriate per directory)?
Aimdezilaere
(Or are you apt to have any general file type in said directories?) therube, 05 Dec 2025, 17:15
No, its a seperate fileformat, you cant rename a .gdoc to .docx
The only way to get Google-specific file formats off of Google Drive is to convert them into different formats (as you suggested). Problem is, this isn't really a "synchronization" operation...
