RTS Log window
d.vertz
After performing the sync, RTS displays a lo window to display the warnings/errors. The path in this window is so long that it runs off the screen. I have double click this warning message hoping to see the full path. That did not work. I have looked for a button. I can not find one. How can I see the full path so I can fix the warning message?
FYI: The bad date was not on the source file, it was on the destination file.
Picture of example is attached.
therube
Tools | Options -> Default Log Folder:
should contain your log files, & presumably showing the full path in question.
