Hi!
I installed a new version of FreeFileSync this week and tweaked some of the settings.
FreeFileSync is regularly launched via the Windows Task Scheduler.
Now, after every launch, a "Completed Successfully" window appears.
...which is annoying. The solution is probably quite simple...but I can't find it. I'm grateful for any advice.
Prevent Window "Completed Successfully"
Hi xCSxXenon!
I knew it ;-)...it was so simple. And I still couldn't find it. Of course it works. Thanks for the solution and thanks for the quick reply.
cu pflanziscuss
cu pflanziscuss
