Ants
For the past couple of weeks, I am getting error like the following (With almost every task):
ERROR_ACCESS_DENIED: Access is denied. [MoveFileEx]
ERROR_ACCESS_DENIED: Access is denied. [DeleteFile]
Messages about not being able to delete from the recycle bin (On a secondary drive)
I have gone as far as disable some settings which I am not comfortable with:
I have resorted to rolling back to FreeFileSync_14.0_[Donation_Edition]_Setup
I was using the latest.
All give the same errors
Any advice or assistance would be most gratefully accepted.
Ants
I think it was a permissions issue on my secondary drive. Testing now.
Ants
I'm a little embarrassed, it was permissions on the secondary drive.
All 12 tasks finished without issue.
I am surprised that I failed to check this, as this isn't my first rodeo.
Regards.
Loyal lover of FreeFileSync.
