After updated Version to 14.5:
high CPU and after a while PC not responding anymore while copying. I tried 3 times. Last time at 42%, from about 650MB to copy. I also tried to set Threats down to 1 file, the same happend.
The configuration was not changed after update to 14.5. Nothing was changed after update. I use the same Backup from WIN PC to USB over network (SMB)
After that I went back to Version 14.4 and everything is working like before.
Problem Version 14.5
problem news or solved
I found out that there was a problem with vdb4 Database in background, maybe with VSS volume shadow.
so I decided to exclude
<Item>*.vdb4*</Item>
now it's working again, even with FFS 14.5.
