As far as I can tell, there is no easy way to tell from a post-sync command whether any files were synced. If there was nothing to sync, the sync operation is considered successful.
It would be great if there was a way to run a different command based on whether any files were synced, for example so I could not create a new archive of the synced files if no files were synced, since the archive contents would be identical.
If I am incorrect and there is a way to do this please let me know. As far as I understand the current implementation, I would need to find and parse the sync logfile to determine whether any files were synced.
Suggestion: Post-sync command conditioned on whether files were synced
I don't know (?) if FFS sets %errorlevel%, but if it did... you might be able to check against that.
Pseudo-code:
grep -i "Items processed: 0 (0 bytes)" *.log > /dev/nul
if %errorlevel% == 0 goto nothinghappened
:nothinghappened
exit
Pseudo-code:
:nothinghappened
exit
Thanks for the response, therube. That is a nice thought, but based on the documentation and my observation, there is no errorlevel associated with this condition. FreeFileSync.exe returns with errorlevel 0 as long as execution was successful, regardless of whether any files were copied or not.
From the online manual:
Exit Codes
0 Synchronization completed successfully
1 Synchronization completed with warnings
2 Synchronization completed with errors
3 Synchronization was aborted
Exit Codes
You could parse the log file to obtain the number of items and base the actions off that
Yes, parsing the log file has crossed my mind (and was suggested to me by Copilot). I would prefer not to do this since it is not a robust approach, e.g. I may not be aware of some corner cases in the log file format, or the format could change in a future release in a way that breaks my log processing code.
I've added scripting support for the next FFS version!
Instead of having only the exit code to work with, all the relevant sync statistics are returned for scripts to evaluate: https://freefilesync.org/manual.php?topic=scripting
FFS 14.6 Beta - Windows
FFS 14.6 Beta - Linux
Write sync statistics to stdout as JSON for .ffs_batch
Thanks Zenju, that looks great!
Is it recommended to install the beta on top of the existing version, uninstall and install the beta, or install the beta in a different folder? I am running 14.5 donation version right now.
I installed it in a separate folder for now in case I run into bugs and tried out the new scripting support. So far it seems to be working great! I will let you know if I find any bugs.
If I were to install this on top of the released 14.5 donation version would I retain the benefits of the donation version?
No, the donation edition files/flags/license is baked into your unique installerIf I were to install this on top of the released 14.5 donation version would I retain the benefits of the donation version? ravishahani, 18 Nov 2025, 20:47
T'hanks, xCSxXenon.
I installed the beta in a different folder, but it seems to have broken the 14.5 donation version. I guess I will just use the beta version unless I run into a blocking issue.
