New version 7.2 crashes on Windows XP SP3
ne1eaton
Version 7.0 works fine. I haven't tried v7.1, I will if I can find a kit.
I get an illegal instruction exception code 0xc000001d at address 0x00000000004046d0
My cpu is an AMD Athlon XP 3000+ which does not support SSE2 instructions, which I strongly suspect is the problem.
ne1eaton
Just installed v7.1, and it also works fine on my system.
Can you post the full error message that you are seeing?
el3gon
AppName: freefilesync_xp.exe AppVer: 7.2.0.0 ModName: freefilesync_xp.exe
ModVer: 7.2.0.0 Offset: 000046d0
Athlon XP2500+ (no SSE2) on XP sp3.
v.7.1 works fine
Thanks! There was indeed some stray SSE2 instruction at that location. I've updated FFS and re-uploaded version 7.2. FFS should load correctly on CPUs without SSE2 now.
ne1eaton
I can confirm the new v7.2 works fine on my system. Thank yo for fixing this so quickly!
