Sync problem with paired files
blandyna
Dear all,
I love FreeFileSync and it solves most of my copy/backup/synchronization wishes.
But yet, I have a problem. I have a lot of photographs with several names and versions.
The filter have to use: *-normal.jpg for copy from left to right. I need only the copy.
But the filter use paired files, like *-normal.jpg and *-normal.jpg.dop or xmp.
And so I have one time worked the filter one time, and the next time is the filter empty. Next time is OK and so on.
Do you have an idea how I can ignore the paired files? I need only the jpg. Not more. I need this way for third backup of my complete JPG files in my GoogleDrive.
Thanks for any ideas and best!
Blandyna
