1. If I delete a file on my side - it delets on the otherside too. Why?
2. Is it possible to move deleted files into the Trash on the other side (network-side) not permanently delet?
1. it looks correct and shouldn't be deleting on the other side. In order for it to work, though, you must run the sync once to create the sync.ffs_db file that tracks these changes. Have you synced once yet? If so, check that the "sync.ffs_db" files exist in both locations you have selected in FFS.
2. No. You do not have access to the Recycle Bin on the remote computer hosting the network shares. You CAN use versioning in FFS to "make your own" recycle bin. Check the FAQs and Manual.
Roge
Thanks for repaly.
For 2)
I had already suspected that.
I will try your suggestion.
For 1)
Unfortunately my files are going to be deleted.
What I'm doing:
Both side are synchronised.
Now I delete a File on my side (PC) - after new synchronisation that file will be deletet as well on the other side (Network-PC)
I thought, with my settings it shoudn't. The third position in the picture (delet) are "-".
I don't understand way.
Verify that the "sync.ffs_db" files exist in both locations you have selected in FFS.
