FTP not working
blues12
I don't know what I am doing wrong. I enter the exact same logon information that works everywhere else (FileZilla, FTP-WinSCP) - but after a few seconds I get this error message
Cannot find the following folders:
sftp://XXXXXXX.server-home.org/
You can ignore this error to consider each folder as empty.
The folders then will be created automatically during synchronization.
Failed to connect to SFTP server "XXXXXXX.server-home.org"
Error Code LIBSSH2_ERROR_AUTHENTICATION_FAILED: Authentication failed (username/password) (libssh2_userauth_password)
The XXXXX are not shown, I used them to hide the real name
freddos77
I´ve still the same problem (Ver 7.7) ! Who can help?
Currently FTP is not supported, only SFTP.
maddin
I installed FFS 7.9 on a Windows 2003 Server, but the globe to select a SFTP Folder is missing. Resizing the screen did not help. On a windows 10 client all worked fine. I take the GUI File from Win10 and opened it in W2k3.
I get the same errormessage, like above. Are there any requirements for SFTP to get it working?
Maddin
Are there any requirements for SFTP to get it working?maddin
FreeFileSync's SFTP implementation requires Windows Vista or later.
