Recent upgrade took away a feature.
NatHillIV
I just upgraded (sent a donation at the same time). I think I used to use version 14.2, then upgraded to version 14.5 today.
It works fine, but when it is done syncing it no longer shows the result of the sync. It used to leave behind the results of what it had done, similar to a comparison. I really liked that feature.
Is there a way to restore the results showing up after a sync like they used to?
You saved your settings and checked the box to auto-close the window. Re-save your config and make sure not to check the auto-close box.
NatHillIV
I changed nothing. But I will try to figure out how to NOT auto-close. Thanks for the quick response and I will "call again" if I can't figure it out.
THANKS!
Nat Hill IV
NatHillIV
I'm actually not quite sure how I fixed it, but it's working like it did before.
THANKS AGAIN!
