14.6 Default Folders
vuldub
There appears to be a change in behaviour when selecting the browse button. Instead of defaulting back to the last location for that specific selection, it defaults to the last location. Its dangerous, because it might be defaulting to the target you last browsed and not the source that is currently selected. So if I select browse on the source box, chose a folder, then select browse on the target box, chose a folder. Run the sync, the select browse on the source box - it defaults to the selected target folder, not the source folder.
I don't have this behavior in 14.6
When I click browse, on either side and if the location is accessible, it opens a window with that location opened
vuldub
I am happy for you, but that how mine is working.
Last selection for left/right folder pickers are remembered separately by FFS. So I can't imagine how source and target selections could be mixed up. What operating system? Can you provide detailed steps that reproduce this behavior?
