i get errors because of that file has lock my drive out from doing any more sync from it. all i get is errors
how do i delete that file it is lock on that drive and i cant delete it at all. i have this installed on linuxmint 22.2
i have webmin installed and it can not delete it under file management
How to delete that sync.fss._lock file from my drive i get errors from it
FFS should detect that it is abandoned and delete it automatically. You can also delete it manually. If you aren't able to, check permissions on the file. If you still can't, are you sure the drive is healthy?
