Suggestion for controlling and managing rules
vika51
For practical reasons related to managing and controlling the entries defined in the "Name" column, could we consider adding a menu in "Tools" that would allow us to list (and print) all or some of these entries, with a complete list of the defined parameters and their values ​​for each entry ?
Hoping this suggestion will receive your attention.
Best regards
You can open your configurations in something like Notepad++. They are basically just XML files
vika51
Thanks for your reply. I agree that we have all the information we need to manage and control the definition settings, clearly presented through the application and its menus, and also available digitally via the HTML configuration files.
My suggestion is to present this information in an accessible and readable format, similar to the logs, which are available in HTML or plain text.
I simply propose that we be able to easily and automatically edit the configurations and their settings in a text format.
I agree with you that everything is possible with the current state of the product, but I just suggest making it easier to read all the definition settings by allowing us to print them.
Best regards
