OS: Windows 10
I inadvertendly happen to sync the content of a folder containing two subfolders named "NATALE 2013" and "Natale 2013" to a target folder.
Each folder contained exactly the same files.
Attempting to mirror sync, I get the error "Cannot rename file ..." (referring to a temp filename (I do not have the exact error message).
I first tried to delete the target subfolder but the problem continued.
The problem solved as soon as I delete the source subfolder namerd "NATALE 2013".
This suggest that FreeFileSync does not take into account the case of the name of a target folder when generates the temp filename.
Cannot rename file
Correct.
Just like in Windows, file- and folder-names are not case sensitive in FreeFileSync (FFS).
So, "NATALE 2013" and "Natale 2013" are considered to be one and the same.
No, the opposite is true, you're getting an error *because* FFS carefully considers case and does not consider them to be the same. Your target file system however is a different story.
Please tell us what file system are the source and the destination.
In Windows the default behavior is case-insensitive, but, from Windows 10 1803 up, you can use fsutil to enable a per-directory case-sensitivity.
Did you enabled this attribute in the folder containing the two mentioned source folders?
