Days since last sync
Xeroid769
The days since last sync turns red after 7 days of not running a job / task. Is there a way to change that to turn red after 30 days for a particular job / task? Also, is there a way to manually move the tasks to be in an order of my choosing?
If I remember correctly,
No
No, you can color code
Right-click on the column label and select "Highlight...":
Xeroid769
Thank you, Zenju!
Right-click on the column label and select "Highlight..." Zenju, 04 Jan 2026, 18:04
Well that slipped by, nifty! Didn't find anything in any release notes or docs about it, but maybe it's always been there.
Xeroid769
Well that slipped by, nifty! Didn't find anything in any release notes or docs about it, but maybe it's always been there. xCSxXenon, 04 Jan 2026, 20:55
I was actually hoping that I could configure it for each task, but what Zenju posted will just have to work. I have 4 tasks, but there is only one task that I only want to turn red once it reaches 30 days.
