Clear date TimeSpan
Seated1
Hi to everyone here and happy new year.
I used FFS to generate a directory with all change files from 2025. It is my understanding that this TimeSpan is not saved with a particular configuration. I assume then that the TimeSpan is applied to any configuration that I run. Please comment if anything I said is incorrect.
I have looked at your manual and searched the forum and I don't see how to clear the TimeSpan. How may I clear a TimeSpan so that all files are looked at, not just those within a date range. Thanks.
In the filter tab of a configuration's settings
Seated1
Where please? I do not see it on the Comparison tab, Filter tab or Synchronization tab.
The Time span on the Filter tab is not the one I am referring to. On the main screen, if you right-mouse click on the column Relative path, you get a menu. Select "Select time span..." at the bottom. It is this from-thru date range that I am referring to.
It doesn't save that setting between comparisons
Seated1
So it clears it after each sync? Okay, that's fine.
Not to beat a dead horse but I will concur with the numerous posts regarding filtering on date. Thank you in advance for enhancing your filtering on dates. It would be very helpful.
