The software is great
The software is great. It would be even better if the size columns could display units such as GB, MB, KB, etc
Yah I agree.
The only way I can think of to display it in megabytes is to export the file list to a CSV and edit it in a spreadsheet and use a formula to convert bytes to megabytes.
(IMO) If ones Compare is Time & Size, one is much more likely to run into situations where Time & Size (with size displayed as KB...) that you may end up questioning why a update to a file is wanting to occur when the files on each side are the "same" time & "size.
Everything has a problem in identifying duplicate content.
